  3. QRC run error
  • Views 15464
QRC run error
cindykueecs
cindykueecs over 11 years ago
HI All,
I did Assura DRC and LVS check for IBM 180nm technology (7RF), it went on well. And then I tried QRC and the QRC terminated abnormally. Please check the detailed error message as follows:
-blocking singleEndA_shield4:0.02/opt/cadence/PVE121/tools.lnx86/extraction/bin/64bit//capgen: error while loading shared libraries: libtermcap.so.2: cannot open shared object file: No such file or directory
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
My Assura current version is:
Assura (R) Physical Verification Version av4.1:Production:dfII6.1.6:IC6.1.6.500.4
Release 4.1_USR4_HF16
Please let me know any suggestions to resolve this issue.
Thanks in Advance.
Yang
    It looks as if you have a package missing. Looking on my machine, this is at:
    /lib/libtermcap.so.2
    /lib64/libtermcap.so.2
    It appears to be the 64 bit version, so the second. On RHEL6 I have this rpm:
    compat-libtermcap-2.0.8-49.el6.x86_64
    or:
    compat-libtermcap-2.0.8-49.el6.i686
    for the 32-bit version. The subversion will be different depending on the OS etc, but you need to get these (at least the first) installed.
  • cindykueecs
    Thanks Andrew, Our problem has been solved. The QRC is running ok now.
