  3. ADEXL dc sweep
  • Views 14630
ADEXL dc sweep
TFTIC
TFTIC over 11 years ago
I have a top schematic (symbol) connected to 4 voltage sources vdc (say V1, V2, V3, V4) and I use ADEXL.
The two (V1, V2) of the voltage sources have defined dc values (actually I define in each source in the schematic a parameter as a dc voltage value say Vone and Vtwo, to which I give through ADEXL some values so as to examine different corners).
The problem starts from now and on:
I want to sweep the other two (V3 and V4, their dc voltages are defined in the schematic as Vthree and Vfour). The sweep I want to do is for Vthree: 0->Vdd and for Vfour: Vdd-->0 (I want to use Vdd, not a specific value).
When I use the variables window (and the parameters tab) through ADEXL, and I try through the Value tab to sweep from/to 0-->Vdd I am not allowed to do it (the same for Vdd-->0).
Could anyone suggest any solution to this problem?
BR
G
