  3. How can Assura differentiate between drain and source of...
  • Subscribers 133
  • Views 16170
How can Assura differentiate between drain and source of MOS transistor??
archive over 19 years ago
I have a question about assura (or LVS extractor in general), how can the tool determine if the pin is the "drain" or "source" of the transistor??
Can I control that to get special output netlist (SPICE netlist)..??
Thanks in advance,
Ahmad
Originally posted in cdnusers.org by ahmad_abdulghany
    I'm not really an expert but I believe the tool doesn't really make a distinction between source & drain. It simply matches nets in the device and the connectivity takes care of itself. Now if you are talking about a simple layout cell you are making for your individual device then I would create & place pins on the sorce & drain and make the labels match the pin names from the symbol view.
    Originally posted in cdnusers.org by bthayer
