  3. How to plot one signal versus another in ViVa (to get an...
  • Views 15855
How to plot one signal versus another in ViVa (to get an eye diagram)
azde
azde over 11 years ago
The eye diagram tool is inadequate - it needs to make the x-axis the UI - unit interval, rather than time.
So, I generate a waveform that is a sawtooth and rises from 0 to 1 in the period of the signal whose eye I'm interested in. (and falls back to 0 in 1 ns, effectively giving me a time base)
Now, I want to plot the DUT output against this sawtooth to get an eye.
How? The Y vs Y is not very helpful. (accessed through right click on the x-axis - generates junk)
Any help would be great.
Thanks!
    Well, that worked for me - the issue is that you'll get a flyback drawn from the end of each period back to the beginning of the next - maybe that's why it is messy?
    Anyway, an alternative would be to use the code below. If I have a signal called "jitter", which has a period of 80n, then if I do:
    abChangeXAxis(v("jitter" ?result "tran") xval(v("jitter" ?result "tran"))/80n)
    and then use the Eye Diagram to produce an eye with a period of 1, it will effectively do what you want. The code will produce a waveform where the X-axis has been scaled to give UI as the time-axis, and then an eye diagram of that would do what you expect (although it's still reported as time). That could be addressed by doing:
    procedure(abWaveVsUI(wave period)
      let((newX yVec)
        newX=xval(wave)/period
        yVec=drGetWaveformYVec(newX)
        yVec->units="UI"
        yVec->name="UI"
        abChangeXAxis(wave newX)
    This alters the axis properties so that they now in units of UI (and the axis is called UI for completeness too).
    Anyway, here's the code for abChangeXAxis:
    /* abChangeXAxis.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 25, 1999
    Modified   May 21, 2002
    By         A.D.Beckett
    Function to change the X Axis of a waveform to the corresponding
    Y values of the second variable.
    Also function to transpose the X and Y axes of a waveform.
    Now handles families, and can be registered as a special function.
    Just call:
    abRegChangeXAxis()
    to add to the calculator.
    SCCS Info: @(#) abChangeXAxis.il 11/27/08.09:59:36 1.3
    *                    (abChangeXAxis yVar xVar)                     *
    * Return a new waveform object with the x axis set to the y values *
    *                     of the second argument.                      *
    (procedure (abChangeXAxis yVar xVar)
      (let (newWave)
        (cond
          ; Handle normal waveform
          ((drIsWaveform yVar)
           (setq newWave (drCreateEmptyWaveform))
           (drPutWaveformXVec newWave (drGetWaveformYVec xVar))
           (if (eq (drGetWaveformXVec yVar) (drGetWaveformXVec xVar))
             ; if the x axes are the same for both, it's simple
             (drPutWaveformYVec newWave (drGetWaveformYVec yVar))
             ; otherwise need to use value() to interpolate
             (let (xVec yVec len)
               (setq xVec (drGetWaveformXVec xVar))
               (setq len (drVectorLength xVec))
               (setq yVec (drCreateVec (drGetWaveformYType yVar) len))
               (for ind 0 (sub1 len)
                    (drAddElem yVec (value yVar (drGetElem xVec ind)))
               (drPutWaveformYVec newWave yVec)
           newWave
          ; Handle family
          ((famIsFamily yVar)
           (famMap 'abChangeXAxis yVar xVar)
           ) ; is family
          (t
            (error "abChangeXAxis - can't handle %L\n" yVar)
          ) ; cond
        ) ; let
      ) ; defun
    *                         (abRegChangeXAxis)                          *
    * Registers abChangeXAxis as a new special function in the calculator *
    (procedure (abRegChangeXAxis)
      (calRegisterSpecialFunction
        (list "abChangeXAxis" 'abChangeXAxisCB)
      t
    *                            (abChangeXAxisCB)                             *
    * Callback function for the special function - which builds the expression *
    (procedure (abChangeXAxisCB)
      (calSpecialFunctionInput 'abChangeXAxis '(STACK))
    *                     (abTransposeXY var)                      *
    *             Swap the X and Y axes of a variable              *
    (procedure (abTransposeXY var)
      (let (newWave)
           (drPutWaveformXVec newWave (drGetWaveformYVec var))
           (drPutWaveformYVec newWave (drGetWaveformXVec var))
           newWave
