  3. Display a custom message while hovering the mouse over a...
  • Views 15945
Display a custom message while hovering the mouse over a particaluar instance in schematic
loboveena
loboveena over 11 years ago
I am trying to display a customized info message for a particular instance while hovering the mouse over an instance in a schematic window.
 I tried using schRegPopUpMenu but this applies only if I right click on any instance in the schematic. Is there any function in skill where I can hover the mouse and display a custom menu ?
Veena
  • Quek
    Quek over 11 years ago
    Hi Veena
    I think there are 2 possible solutions to the problem:
    a. Use the built-in info-balloon function which can be enabled in "Options->Dynamic Display". You can customize the contents of the info-balloon using odc* SKILL functions which are described in $CDSHOME/doc/sklayoutref/sklayoutref.pdf.
    b. Use the object info display skillscript in COS article 11519912.
    Best regards
    Quek
  • loboveena
    Hi Quek,
    Thanks for responding. I am interested in displaying info for a instance in a schematic window only. The odc* functions are only supported with VXL.
    However the objectinfo skillscript is useful and I can customize this based on my need. But how I make this info to be display dynamically (or for a few seconds) while hovering the mouse without asking the user to press any key or select the instance ?
    Veena
