  3. Info on a schematic symbol on the used config view
  • Views 15783
Aldo2
Aldo2 over 11 years ago
Is it possible to see on a symbol the schematic view selected by the hierarchy editor?
I there a label like [@libName] or [@instanceName] giving this information?
Thank you
Best regards
Aldo
    Aldo,
    You can use Launch->Plugins->Hierarchy Editor (in IC615 and before there's no Plugins level in the menu though), and then in the Hierarchy-Editor pulldown you can use the Show Views Found menu item. Note that this is not persistent in the schematic editor - and shows a coloured highlight plus text label to show the view bound. It goes away as soon as the command is cancelled.
    If you want a more permanent label, you can use this SKILL code - create an ILLabel on the symbol with text of the label being abWhichView(), and ensure that the SKILL code is loaded (e.g. from your .cdsinit).
    /* abWhichView.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Oct 03, 2005
    Modified
    By
    Function which can be used as a label on a symbol, to say
    which view is being used in a config.
    Create an ILLabel, with value "abWhichView()"
    SCCS Info: @(#) abWhichView.il 10/03/05.15:07:34 1.1
    *                   (abWhichView [instId] [wid])                   *
    *     Returns the name of the view bound in the config, or nil     *
    * if there is no config. instId defaults to ilInst - the currently *
    *     drawn instrane, and wid defaults to the current window.      *
    (procedure (abWhichView @optional (instId ilInst) (wid (hiGetCurrentWindow)))
      (let (pathVector bindInfo)
           (setq pathVector (deGetVector wid))
           (when pathVector
                 (setq bindInfo
                       (hdbBind
                        pathVector
                        (dbGetq instId libName)
                        (dbGetq instId cellName)
                        (dbGetq instId viewName)
                        (dbGetq instId name)
                        nil nil nil
                 ; The third entry in the list is the view used
                 (caddr bindInfo)
                 ) ; when
           ) ; let
      ) ; procedure
  • Aldo2
    Thank you very much Andrew
