  3. Flicker Noise in Pnoise Analysis
  • Views 17967
Deepansh
Deepansh over 11 years ago
I am a beginner, working on the design of a low-noise amplifier using Cadence Spectre. I wanted to know if the Pnoise analysis in the Analog Design Environment considers the flicker noise of [all] the transistors?.If not, kindly let me know any changes I would have to make to include flicker noise contributions, since this is essential for  my design.
Thank You
    Yes, provided that your device models model flicker noise (which most transistor models would these days). Depending on the type of transistor model there are different parameters to control this (so for bsim4, see "spectre -h bsim4" for more details on the parameters). Apart from that, there's nothing special you need to do to enable this.
    Kind Regards,
  • Alokkr5
    Alokkr5 over 6 years ago in reply to Andrew Beckett
    Hello Sir!
    I request you to provide information as to how to calculate or if possible plot Flicker noise (1/f) in Cadence Virtuoso ADE.
    I am designing an instrumentation amplifier.
    Andrew Beckett over 6 years ago in reply to Alokkr5
    See my answer above in the thread. It's unclear to me what you're really asking - spectre will simulate flicker noise in a noise/pnoise/hbnoise analysis (etc) provided that the device models have flicker noise parameters defined - then all the flicker noise contributions will add up to the total output noise.
