  3. NCF (netlist compiled functions) equivalent for bsource...
  • Views 14672
NCF (netlist compiled functions) equivalent for bsources
fgarcia
fgarcia over 11 years ago
I am trying to model a device which behavior implementation requires from some C/C++ functions.
In http://community.cadence.com/cadence_technology_forums/f/92/t/31049 I have been pointed to use NCF, but these functions are limited in use when called from bsources. CMI does not suit the solution: it is to much complex.
I want to know if any other NCF equivalent compatible with bsources exists.
    No, they don't exist. As I mentioned in my reply to your previous post, the arguments to the NCF must be constant (i.e. not voltages or currents).
    If you have a specific requirement, I'd suggest you contact customer support so that we can explore if there are any other ways of achieving your overall goal.
