  3. Electromigration/IR drop (EMIR)
  • Views 10676
TFTIC
TFTIC over 11 years ago
I setup a transient simulation from a terminal (without the use of ADEXL).
I use dspf netlist for a post-layout simulation and I want to use the emir option for electromigration/ir drop simulation.
I have the following questions/notices considering this procedure:
In the input.scs I do:
__________________________________
dspf_include="path/file.dspf format"
considering the extracted netlist in dspf format.
Then in the input.scs file I make to sections:
a) with the simulatorOptions (gmin etc) and
b) with the transient options (stop time etc).
the problem: I want to do the EM/IR analysis as it is described in spectreuser.pdf manual, section of post-layout simulation.
So, I add a line of the form in the input.scs:
emir="path/emirconfigfile.conf"
where the .conf file is the configuration file. My conf file has the following lines (doing what it is described in the manual):
________________________________________________________
solver method=[auto]
net name=[I0.*]
analysis=[imax]
emirutil emdatafile="./emmodel.txt" violation-map=all notation=[e]
_________________________________________________________
I0 is an instance
Questions:
1) Where do I add the emir=" " statement, in what section (in the simulationOptions, elsewhere)?
2) Is my .conf file correct?
3) The dspf file that I get from the extraction has some nodes of the form:
GAIN.XBOX_L<0>/XI0/MPG1:d
How could I probe this after my simulation? What I did (without success) I put in the save section
of input.scs:
GAIN.XBOX_L\<0\>/XI0/MPG1:d
Thank you
BR
G
    I would suggest you start by looking at the example that's in:
    <MMSIMinstDir>/tools/spectre/examples/EMIR_workshop/APS_EMIR_Workshop.tar.gz
    There's both an ADE example and a textual example. You'll see that the EMIR conf is passed on the command line to spectre via +emir=emir.conf .
  • TFTIC
    Hi Andrew, thank you for the feedback, I will take a look in this workshop (actually I did not know the existence of this workshop). From reading the spectreuser.pdf (accelarated and parallel ....) I did not manage to setup the conf file (the +emir=emir.conf is described in the spectre manual, however I think that I miss some other details). Hope that the workshop will help me. BR G
