  3. Unable to use rmsNoise function
  • Views 16663
Deepansh
Deepansh over 11 years ago
I am using virtuoso 6.1.3 to design a low noise operational amplifier. I used the PSS+Pnoise analysis in ADE to plot the input referred noise of my op-amp.However, when using the rmsNoise function in the Visualization and Analysis  L Calculator , I am getting the following message in the CDS log:
"rmsNoise(10 20k )"
*Error* rms Noise data not available
Expression evaluation failed: Expression evaluates to nil
nil
I suspect I might not be using the function in the right way.Can someone please guide me on how to use this function?Do I have to do something apart from what was mentioned in the Waveform Calculator Guide?
Thank You
    The rmsNoise function only works using the result of the noise analysis (not pnoise). You'd need to do thiss:
    sqrt(integ(getData("out" ?result "pnoise")**2 10 20k))
    Essentially rmsNoise is doing something similar, but effectively with ?result "noise" rather than ?result "pnoise". You'll see this is integrating the square of the output noise (which is in V/sqrt(Hz)) over a frequency range of 10 to 20kHz, and then taking the square root of the result.
  • Deepansh
    Hey Andrew,thanks for replying to my post.I indeed did try the code which you provided, and it works fine.Thank you for your help!
