  3. Reducing the size of simulation result files
  • Views 15207
Pyroblast
Pyroblast over 11 years ago
Hi guys, how are you?
I would like to know if there is someone here that could tell me how to reduce the size of the simulation files because I want to perform a massive top simulation and I don't have enough quota space on the serve.
I have been told that it might be possible to reduce the size occupied by the simulation files removing some options and more, tell the simulator to show only some node voltages.
The analysis that I will perform is transient.
Thanks.
  • NovikovBoris
    NovikovBoris over 11 years ago
    You can use Ultrasim simulator and save only special nodes and currents to minimize result files. Ultrasim has less result file space then spectre.
