  3. how to find number of crossings of a signal above a thershold...
  • Views 18465
vamshiky
vamshiky over 11 years ago
HI,
I tried using cross function to get all crossing but now need the count for these crossings.
length( cross(...) )  failed to evaluate.
Vamshi
  • Tom Volden
    Tom Volden over 11 years ago
    Hi Vamshi,
    cross() returns a waveform, so length will not work.  You need to convert it to a vector and then get the vector length.  Try:
    drVectorLength(drGetWaveformYVec(cross...))
    TOM
    If the crossing number is passed as 0, it should return a list of the crossings rather than a waveform. What precise arguments did you give to the cross function? Regards, Andrew.
  • vamshiky
    Thanks for the reply Andrew,  it works now.
    Earlier I tried using 'No. of occurences' as multiple and so it failed to evaluate.
    @TOM,  Thanks your solution also works.
    -Vamshi
