  3. The schematic generated via spicein turns "VDD" port to...
  • Views 3357
The schematic generated via spicein turns "VDD" port to "VDD!" automatically
zczc99
zczc99 over 11 years ago
I am using IC6.15, and I try to import CDL into schematic. However, after importing, the ports "VDD" and "VSS" change to "VDD!"  "VSS!".
How to solve this problem? Here is an example of the netlist:
.SUBCKT XOR3XLM VDD VSS VNW VPW Y A B C
M10 VDD A nmin1 VNW pm_hp L=1.3e-07 W=5.8e-07
M2 net51 nmin2 nmin1 VNW pm_hp L=1.3e-07 W=5.8e-07
M0 net51 B net69 VNW pm_hp L=1.3e-07 W=4.8e-07
M16 VDD nmin1 net69 VNW pm_hp L=1.3e-07 W=4.8e-07
M12 VDD B nmin2 VNW pm_hp L=1.3e-07 W=2.3e-07
M14 VDD net51 net67 VNW pm_hp L=1.3e-07 W=2.5e-07
M1 net54 C net67 VNW pm_hp L=1.3e-07 W=2.5e-07
M3 net54 nmin3 net51 VNW pm_hp L=1.3e-07 W=5.7e-07
M8 VDD C nmin3 VNW pm_hp L=1.3e-07 W=3e-07
M18 VDD net54 Y VNW pm_hp L=1.3e-07 W=3.6e-07
M11 nmin1 A VSS VPW nm_hp L=1.3e-07 W=4.8e-07
M6 net51 B nmin1 VPW nm_hp L=1.3e-07 W=4.8e-07
M4 net51 nmin2 net69 VPW nm_hp L=1.3e-07 W=3.7e-07
M17 net69 nmin1 VSS VPW nm_hp L=1.3e-07 W=3.7e-07
M13 nmin2 B VSS VPW nm_hp L=1.3e-07 W=1.9e-07
M15 net67 net51 VSS VPW nm_hp L=1.3e-07 W=2.1e-07
M5 net54 nmin3 net67 VPW nm_hp L=1.3e-07 W=2.1e-07
M7 net54 C net51 VPW nm_hp L=1.3e-07 W=4.8e-07
M9 nmin3 C VSS VPW nm_hp L=1.3e-07 W=1.9e-07
M19 Y net54 VSS VPW nm_hp L=1.3e-07 W=1.8e-07
.ends XOR3XLM
Thank you.
  • Steven Mikes
    Steven Mikes over 11 years ago
    I remember having this same issue, I just renamed the nets manually after importing. That's probably not your preferred solution though :)
  • zczc99
    Manually change these names will be physical work, because it is a standard cell library, there are hundreds of cells :(
  • Steven Mikes
    This is not the ideal solution, but it's a good work-around:
    Open up one of the schematics in your library and on the menu bar go to Edit -> Replace
    Search For -> netName == VDD!
    Replace With -> netName  VDD
    Search Scope -> library  [your lib name]
    should do the replacement for the entire library. Repeat for GND/VSS if necessary :)
  • zczc99
    Hi Steven, it works perfectly. Thank you:)
