  3. How to find all the crossing of the signal
  • Subscribers 133
  • Views 26840
wgtkan
wgtkan over 11 years ago
I used the cross function to get all the crossings and plot the waveform. But it didn’t display all the crossings.
I am trying to plot pulse vs temperature. This is what I have done. I performed a transient simulation in ADEL by specifying the stop time to 400ns.
Then did a parametric simulation of temperature for from -50C to 125C linear step size of 10C. It gave me the transient response at the specified temperatures.
I used the cross function to return the plot of the pulse vs temperature. The plot doesn’t look correct because it only gave me part of the time. It didn’t give me the whole pulse rang from (0-400ns)
How do plot the whole time vs temperature. (0-400ns) vs -50 to 125C
I am attaching the plot with this question.
Here is the argument that I gave to the cross function.
My output signal VT(“/Pout”)
Threshold value: 0.75
Edge number: 2
Edge Type: either
Number of Occurrences: Single I tried multiple also but it plot time vs time.
Plot/print vs: time
My understanding is that the cross function returns the x value where a signal crosses the threshold y value.
Thank you.
    ShawnLogan over 11 years ago
    Dear wgtkan,
    The expression for the cross() function shown above your plot of its result is for a single waveform crossing. Hence, the y-axis is limited to the maximum initial crossing of your signal. You noted that you also tried multiple crossings. What expression did you try? I use the cross() function extensively. A typical multiple crossing use of the cross() function to obtain the x-crossing values about a 0.0 thrreshold  as a function of the waveform cycle is:
    cross(hsclki_clipped 0 0 "rising" t "cycle")
    where "hsclki_clipped" is a clipped waveform.
    Shawn
  • wgtkan
    Dear Shawn:
    I tired the expression you gave me and this is what I get. It not still what I want:
    cross(VT("/Pout") 0 0 "rising" t "cycle" )
    It gave me multiple plot as a function of cycle.
    And when I use cross(VT("/Pout") 0 0 "rising" t "time" )
    It gave me pulse vs pulse.
    I want to plot the pulse vs temperature.
    Thank you
  • wgtkan
    Dear Shawn:
    Thank you
    Dear wgtkan,
    If you are trying to plot pulse width as a function of temperature, what I might suggest is that you write an expression for the pulse width using a series of cross() functions. For example, the width of the first rising edge to falling edge pulse about a voltage threshold vthreshold, it might be something like:
    cross(pout vthreshold 1 "falling" nil nil)-cross(pout vthreshold 1 "rising" nil nil)
    where pout=VT("/Pout" ?result "tran-tran")
    Add this as a plotted output to your ADE-L outputs. Then, perform a parametric simulation as a function of temperature. The resulting ADE=L plot will display the measured pulse width as a function of the temperature range you specify in the parametric simulation. If you want to examine the pulse width of additional pulses, add expressions to the ADE-L Outputs that define the width of the additional pulses you want to study.
    Shawn
  • wgtkan
    Hello Shawn:
    I created cross expressions for various edges of my pulse. I would like to plot the entire pulse range as a function of temperature; my time range is 0-400ns.
    cross(VT("/Pout") 0.6 1 "falling" nil nil  )-cross(VT("/Pout") 0.6 1 "rising" nil nil  ) in the calculator for my first edge and send it to the ADEL output. Then performed parametric sweep. It gave me the pulse of the first edge as a function of temperature from 0 to 17 ns vs the temperature range. Do I have to add the additional pulses to the previous expression? Like this?
    cross(VT("/Pout") 0.6 1 "falling" nil nil  )-cross(VT("/Pout") 0.6 1 "rising" nil nil  ) +
    cross(VT("/Pout") 0.6 2 "falling" nil nil  )-cross(VT("/Pout") 0.6 2 "rising" nil nil  )
    Thank you
