  3. Taking Picture of Schematic
  • Views 25592
Deepansh
Deepansh over 11 years ago
I need to take a picture of my schematic, with a white background and the circuit (wires,transistors etc.) in black.I'm using Virtuoso 6.1.3. Can anyone guide me on the same?
Thank You
    File->Export Image (in IC616, and certainly in the IC615 version I have on my laptop) has a section on the form called "Appearance" and has the ability to change from Full color, to Monochrome, to Bi-color, and also allows you to swap the foreground and background colors. So that should do what you want.
    In IC613 you could set the background color on this form, but not make it monochrome. I would suggest using something newer if possible (there has been IC614, IC615 and IC616 since, so you're using a long-unsupported release).
    ShawnLogan over 11 years ago
    Dear Deepansh Dubey,
    I use FIle->Print and then save to a postscript file. This preserves the resolution and allows one to zoom in to regions of a schematic not visible or clear on a bitmap image. The postscript file can be converted to eps or pdf format (or png) and the resolution is preserved.
    Shawn
  • Scott Jorek
    Scott Jorek over 11 years ago
     I've always used a screen capture program such as IrfanView (freeware/shareware).  Print Screen, crop then invert (negative).  It won't give you a high quality image but I found it to be sufficient for general documentation of schematics.
