  3. How to find rms input referred noise
  • Subscribers 136
  • Views 30634
Deepansh
Deepansh over 11 years ago
Hello all,
I'm working on the design of an operational amplifier using Virtuoso 6.1.3. On doing a Noise Analysis and then Print->Noise Summary and then printing the  noise integrated  in a bandwidth of 50Hz to 8kHz, I got a statement in the Results Display Window which says 'Total input referred noise is 2.778e-06. Is this the rms value? I'm asking so because I need to find the rms value. If it is not, can someone please guide me on how to compute it?
Thank You
    rmsNoise() will give you the integrated output noise in V/sqrt(Hz), and it will match what is shown on the noise summary (for output noise) if you set the units to V (and give the same integration range). If you want it in V^2/Hz, you can of course square the result.
    If you want to compute integrated input referred noise, you'd do:
    sqrt(integ(getData("in" ?result "noise")**2 1 1G))
    This is integrating between 1Hz and 1GHz in my case, and is also giving the result in V/sqrt(Hz). This will match what you see on the noise summary for input referred noise. So both the figures on the noise summary are RMS (if the units are in V rather than V^2, otherwise they are mean-square rather than root-mean-square).
