  3. Layout XL (IC 5.1.41) routing
  • Views 15091
James Hsu
James Hsu over 11 years ago
Kindly  People:
I'm using Layout XL (IC 5.1.41) function for routing use .
Has also been set up>    icc.rules,
But when I chose create> wire,
Create Wire form did not displayed, why?
Who can help me?
  • James Hsu
    There were several warning messages in CIW as below :
    1. *WARNING* Export from DFII:Techfile param iccLayers is not defined.
    2. *WARNING* Export from DFII:Cannot export (jj comp layout) from DFII .
    The iccLayers section is nil.empty or undefined in techfile or rules file .
    3. *WARNING* Error during layer table initialization .
    4. *WARNING* Unable to load design data : library jj cell COMP view layout
    5. *WARNING* Write Editor library unavailable for 'command_start' command
    6. *WARNING* WE : Failed to init .
    Clearly your icc.rules is wrong. Try taking a look at an icc.rules file from (say) gpdk180 which can be found at
