  3. Aging simulation with RelXpert
  • Subscribers 129
  • Views 15879
syafiq
syafiq over 11 years ago
I'm currently using IC614 and wanted to run aging simulation. As far as I know, cadence has relXpert to perform this simulation. However, I don't see this tool to run in IC614. Is this tool only available in latest version? May I know which version is that?
And looking at the my software directory:
/home/esdcad/software/cadence/linux/mmsim7.11.188/tools.lnx86
I can see a folder named 'relxpert' and inside this folder a few scripts to run relxpert. but how to run it is not quite clear. I'm just wondering if I can integrate those scripts into ADE-L gui. Do you have any idea about this?
BTW, I've tried the method you mentioned above (setenv RELXPERTHOME $MMSIMHOME) but it just don't work.
Please advise.
Syafiq
  • Quek
    Quek over 11 years ago
    Hi Syafiq
    In accordance with the forum rules, would you please start a new post for your own question? This will help us to focus only on your issue and not be confused by the original issue which was already closed in year 2011.
    Quek
    I split the post off into a new thread.
    If using IC616 (and I think IC615, and even later IC614 subversions), you will file a menu Simulation->RelXpert or Simulation->Reliability which contains the setup (in ADE). You don't have to set any magic environment variables or load any custom code to make this work any more.
  • syafiq
    Thanks Andrew for your reply.
    FYI, I am currently using IC6.1.4.500.6 version and I don't find RelXpert in ADE environment.
    thanks
    syafiq
