  3. IC 5.1.41 , VXL Autorouting error , How CAN I fix them ...
  • Views 14471
IC 5.1.41 , VXL Autorouting error , How CAN I fix them ?
James Hsu
James Hsu over 11 years ago
When I use IC 5.1.41  the  Autorouting :   Routing  >  Export  to  Router  >  Autorouting
There were several  message  in  CIW  as  below  :
Autorouting: Starting  export.
            Exporting "jj COMP layout " from  DFII....
eXPORTING VERSION 11.1.33 syntax from exportVersion  environment variable.
*WARNING* Export from DFII: Techfile param iccLayers is not defined.
*WARNING* Export from DFII: Cannot export (jj COMP layout)from DFII.
                   The iccLayers section is nil,empty or undefined in techfile or rule file.
*WARNING* Error during layer table initialization.
*Error* icciWrite:  Export could not open cellview.
thank you for your kindly.
    Can you please stop posting multiple times. Yesterday you posted the same thing three times (twice in one forum, and once in another). The Forum Guidelines explicitly tell you not to do this - it is annoying, will not get you an answer any quicker, and makes it much harder to track. I tried to consolidate your three posts yesterday, but something went wrong and I think it may have deleted two of the posts.
    So any answers should be made in this thread: http://community.cadence.com/cadence_technology_forums/f/38/t/31225
