  3. Area estimate from schematic
  • Views 18731
archive over 18 years ago
Hello experts, If I have a schematic and have pcells for all the devices used in the schematic, what's the easiest way to get an area estimate ? Thanks! nnxx
Originally posted in cdnusers.org by nnxx
    I think you can invoke VXL from the schematic and then call Design->Gen From Source. This form has option for Area Calculation based on "PrBoundary" or "bBox" of the layout cell. You can select one of them. Explore it.
    Originally posted in cdnusers.org by rairaj
    Thanks rairaj. Actually, I was relying on this method so far but was hoping to find a solution that can be scripted for several blocks so I don't have to open VXL for every block that I want to get an estimate for.
    /tools/dfII/samples/VPR has got area estimation function file areaScr.il . You can use that but you will need to modify it. Because, it simply does l*w on the mos device. It does not consider m , finger etc.. It considers contactArea(including active region to be 1.0, you need to comeup with a figure.) Also, if your devices have a deep nwell then it needs to be considered too.
  • SRNAYAK
    SRNAYAK over 11 years ago
    hi rairaj . i am not getting the script in the global MIT path( /tools/dfII/samples/VPR/ areaScr.il) . can u provide me that please.
