  3. AMS / readic SCS file
  • Views 16005
david0526
david0526 over 11 years ago
hello,
I'm using readic option with AMS to load EE default settings before running my sims.  Presently I have to specify the testbench name for every line item in the .scs file.  Is there a way to make the testbench name a "variable" that can get loaded automatically (instead of me manually changing the .scs file for every testbench in my library)?  I know for probe.tcl files this is possible by doing something like:
>> set testbench_name [scope]
and then using it in the probe statements, i.e.
>> probe -create -emptyok -database ams_database -flow "$testbench_name.I_dut.etc"
Any help would be appreciated!
Thanks in advance.
    I don't understand what you're doing (what are "EE default settings"? Why do you need to specify the testbench name for every line item in the .scs file - it's unclear what you're doing).
    Please clarify (ideally with something to illustrate it)?
  • david0526
    Thank you for the reply, sorry I wasn't very clear.
    I have an EEPROM block that requires initialization.  I've been doing this by specifying a "default_trim.scs" file in the readic field under "algorithm" tab in Transient sim options.  Here's a snapshot of what the file contains (I'm told this is the format that the PDK requires for the EEPROM model):
    (CellName).IDUT.EEPROM.I_NVM.USER_1.M3.INITIALVOLTAGE -1
    (CellName).IDUT.EEPROM.I_NVM.USER_2.M3.INITIALVOLTAGE -1
    (CellName).IDUT.EEPROM.I_NVM.USER_3.M3.INITIALVOLTAGE -1
    (CellName).IDUT.EEPROM.I_NVM.USER_4.M3.INITIALVOLTAGE 1
    (CellName).IDUT.EEPROM.I_NVM.USER_5.M3.INITIALVOLTAGE -1
    (CellName).IDUT.EEPROM.I_NVM.USER_6.M3.INITIALVOLTAGE -1
    (CellName).IDUT.EEPROM.I_NVM.USER_7.M3.INITIALVOLTAGE -1
    (CellName).IDUT.EEPROM.I_NVM.USER_8.M3.INITIALVOLTAGE -1
    where "(CellName)" is the name of my testbench.  "-1" and "1" specify burned/not_burned in my model.  Presently, for every testbench I build I have to manually replace (CellName).  I would like to (ideally) have (CellName) auto-populate so that way I can use only 1 file for all the testbenches (instead of a single file per testbench).
    Please let me know if I'm still not describing the issue sufficiently.
    Thank you for the help.
    I meant to reply to this a while ago, but somehow overlooked it in the run up to Christmas.
    This is not possible as far as I know. I can see why you want to do it, but initial conditions files can't have a prefix added to them, and don't support any parameterization. BTW, giving the file a ".scs" suffix is a bit confusing, because that suggests it is in spectre netlist syntax, whereas in fact it's a "nodeset" or "ic" file (which is just node-value pairs).
    If you want something like this, it would require an enhancement to the simulator, and so you should contact customer support.
    Kind Regards,
  • david0526
    Thank you for the follow-up, Andrew.
    I ended up creating a "unified" testbench for all my tests of interests, this way I keep the testbench name same in the reaic file, and just change variable in the AMS state.
    David
