  3. APS under ADE XL
  • Views 15230
APS under ADE XL
Awny
Awny over 11 years ago
I am working with ADE XL. Once I choose from "High-performance simulation" menu in Tests the option to simulate with "Spectre" and run the simulation, everything is going right and in the "results" tab there are no errors. However, when I change to "APS" in  "High-performance simulation" then I "sim err" in red for all the signals in the "results" tab. I went to the SImulation log and found absolutely no errors. Does anyone know why I get this "sim err" with the "APS" option?
Thanks a lot for your help
    Please contact customer support - we'll need to see this (also will need to know which versions of the tools you're  using).
    Kind Regards,
