  3. Effect of mos fingering in schematic simulation
  • Views 14876
jdp721
jdp721 over 11 years ago
Hi.
What is the effect of mos fingering in schematic simulation of a circuit?
Like I have a mosfet in a schematic, with fixed (w / l) of 33, and on changing the no. of fingers from 1 to 4, some dc operating points are changing slightly.
So how does the device parameters change (if any) ? Kindly tell if you have any info!
    Your best bet is to consult the Virtuoso Simulator Components and Device Models Reference manual (<MMSIMinstDir>/doc/spectremod/spectremod.pdf - also can be located using <MMSIMinstDir>/tools/bin/cdnshelp ).
