  3. incremental techDB and constraintGroups
  • Views 18721
marcelpreda
marcelpreda over 11 years ago
Hi *,
I'm trying to use the ITDB feature in Virtuoso 6.1.6 .
In a few word what I want:
I a base technology db, with some layers/vias, etc..
I want to reference that library and to add a new layer LXX, and to create a new via "cnt_LXX" using (Metal1, Contact, LXX).
The Metal1 and Contact are already defined in the base techdb.
I would like to have the the new cnt_LXX in the same constraint group "virtuosoDefaultSetup" which the activative one by default.
The idea is that when the layouter press "O" (Create->Via...) to have the list of vias all the initial vias plus the new created.
The problem is that in the new teck library I'm not allowed to use the same constraint group name "virtusosDefaultSetup".
When loading the new tech file (ASCII) I get error message
_____________
*WARNING* (TECH-2000000): techCreateConstraintGroup: Constraint group with name virtuosoDefaultSetup already exists.
*WARNING* (TECH-280190): Failed to create constraintGroup virtuosoDefaultSetup.
*WARNING* (TECH-280257): Failed to load technology file from file '..."
_______________
I can change teh name of the group to something like "virtuosoDefaultSetup_LXX" and then to switch the wire Constraint group via Options->Editor, but it is not nice (not productive for designers).
So the question is how can I have the old vias and new via in a common list/constraint which is loaded/set by default?
I have to admit I'm not very familiar with the tech file, but I've read some documents availale on virtuoso install path.
Below is a piece of code from tech file, teh layer definition and few other details were skip.
Best Regards,
Marcel
__________
refTechLibs( "my_baseTech")
; VIADEFS
viaDefs(
 standardViaDefs(
 ;( viaDefName    layer1    layer2    (cutLayer cutWidth cutHeight [resistancePerCut])
 ;   (cutRows    cutCol    (cutSpace))
 ;   (layer1Enc) (layer2Enc)    (layer1Offset)    (layer2Offset)    (origOffset)
 ;   [implant1     (implant1Enc)    [implant2    (implant2Enc) [well/substrate]]])
  ( cnt_LXX          LXX          Metal1          ("Contact" 0.17 0.17)
     (1 1 (0.34 0.34))
     (0.13 0.13)    (0.08 0.08)    (0.0 0.0)    (0.0 0.0)    (0.0 0.0)
 ) ;standardViaDefs
) ;viaDefs
; CONSTRAINT GROUPS
constraintGroups(
  ( "virtuosoDefaultSetup" nil
    interconnect(
     ( validLayers   ( LXX
     ( validVias     (
        cnt_LXX
    ) ;interconnect
  ( "DoubleVia" nil
    interconnect(
     ( validLayers   ( LXX
     ( validVias     (
       cnt_LXX
    ) ;interconnect
  ( "virtuosoDefaultExtractorSetup"    nil
    interconnect(
     ( validLayers   (
        LXX
    )) ;interconnect
  ) ;virtuosoDefaultExtractorSetup
  ( "foundry"    nil
    orderedSpacings(
     ( minOppExtension               "LXXC_Mark"    "Contact"    (0.46 0.46) )
    ) ;orderedSpacings
) ;; foundry
) ;constraintGroups
  • theopaone
    theopaone over 11 years ago
    The virtuosoDefaultSetup is the default name for the router constraint group. With IncTechDB, a constraint group cannot be redefined. This prevents multiple problems when trying to merge the values.
    Create a new constraint group with a reference to virtuosoDefaultSetup. For the users, set their default constraint group to the new group using .cdsenv variable: wireConstraintGroup which governs the wire editor. If you need to affect the extractor, setup a constraint group for that and set the default constraint group using the env variable: setupConstraintGroup. That way, the users do not have to do anything.
    Ted
  • marcelpreda
    Hi Ted,
    Thanks for hint.
    I've just tring using the memberConstraintGroup.
    Now the load/compile of new tech library goes OK, but I can not find the new via in any constraint group, except "foundry" .
    Using skill I get:
    l1 = lxGetValidViaDefs(cv "virtuosoDefaultSetup")
    (db:0x192b9598 db:0x192b9596 db:0x192b9597 db:0x192b9595 db:0x192b9594
        db:0x192b9593 db:0x192b9592 db:0x192b959c db:0x192b959d db:0x192b959a
        db:0x192b9599 db:0x192b959b
    l2 = lxGetValidViaDefs(cv "virtuosoDefaultSetup_add_LXX")
    l3 = lxGetValidViaDefs(cv "foundry")
    (db:0x192b9598 db:0x192b9597 db:0x192b9596 db:0x192b9595 db:0x192b9594
        db:0x192b9593 db:0x192b9592 db:0x192b959d db:0x192b959c db:0x192b9599
        db:0x192b959b db:0x192b959a db:0x192ba312
    My tech file (viaDefs and constraintGroups section) is looking like:
    __________________
    ; VIADEFS
    viaDefs(
     standardViaDefs(
      ( cnt_LXX          LXX          Metal1          ("Contact" 0.18 0.18)
         (1 1 (0.24 0.24))
         (0.13 0.13)    (0.07 0.07)    (0.0 0.0)    (0.0 0.0)    (0.0 0.0)
     ) ;standardViaDefs
    ) ;viaDefs
    ; CONSTRAINT GROUPS
    constraintGroups(
      ( "virtuosoDefaultSetup_add_LXX" t
        memberConstraintGroups( "virtuosoDefaultSetup" )
        interconnect(
         ( validLayers   ( LXX
         ( validVias     (
         cnt_LXX
        ) ;interconnect
      ( "foundry"    nil
        orderedSpacings(
         ( minOppExtension               "LXXC_Mark"    "Contact"    (0.26 0.26) )
        ) ;orderedSpacings
    ) ;; foundry
    ) ;constraintGroups
    _____________
    I've try also : "virtuosoDefaultSetup_add_LXX" t   ; I got the same result
    Did I miss some property somewhere ?
    BR,
    Marcel
    PostEdit: I've noticed that if I comment the line
    the cnt_LXX via is visible in "virtuosoDefaultSetup_add_LXX" grop constraint, but I miss vias from "virtuosoDefaultSetup".
  • marcelpreda
    Finally fixed.
    Insetad of memberConstraintGroups( "virtuosoDefaultSetup" ),
    I had to use list as parameter  memberConstraintGroups( ("virtuosoDefaultSetup") )
    I was expecting an error/warning in the 1st case.
    BR,
    Marcel
  • marcelpreda
    Hi again,
    I was wrong, still didn't work.
    And noticed that when I  use memberConstraintGroups( ("virtuosoDefaultSetup") ) , I get a warning in the CIW
    *WARNING* (TECH-280193): Constraint group member name must be a string.
    BR,
    Marcel
  • marcelpreda
    Hi Ted,
    Any idea what is the proper syntax of memberConstraintGroups ?
    Is it memberConstraintGroups("group1" "group2") ,
    or memberConstraintGroups(("group1" "group2")) ?
    Why I'm asking this:
    I've simplify the things: I created two tech libs ( "myTech_base"  "myTech_flash"), and on the top on new techoptions.
    If I'm using the 1st syntax     memberConstraintGroups(
            ("virtuosoDefaultSetup_base"
            "virtuosoDefaultSetup_flash")
    I get the warning "*WARNING* (TECH-280193): Constraint group member name must be a string."
    But after that all seems to work, I can see all the vias that I wanted.
    If I'm using     memberConstraintGroups(
    I get no warning, but only the vias from         "virtuosoDefaultSetup_base" are visible on the top.
    If I switch the lines  memberConstraintGroups(
    the only the vias from    "virtuosoDefaultSetup_flash" are visible on top
    On top I have now next code:
    controls(
        techVersion("1.0")
         refTechLibs(
        "myTech_base"
        "myTech_flash"
       ) ;refTechLibs
    constraintGroups(
      ( "virtuosoDefaultSetup" t
    ) ; constraintGroups
    which rise the warning, but I have all vias in the "virtuosoDefaultSetup".
    I've test it tens of time, every time restarting virtuoso; to be sure that I'm using a clean database.
    BR,
    Marcel
