  3. Placing an instance with scaling.
  • Subscribers 136
  • Views 18751
Jfer2u
Jfer2u over 11 years ago
In 6.1.6 how do you place an instance with a reduced scaling?  This used to be an option but I can't find it anywhere in the pulldown menus.
  • theopaone
    theopaone over 11 years ago
    Do you mean magnification? OA does not support placing instances at any magnification other than 1.0. You can emulate magnification by converting the data into a pcell with a mag parameter and use dbTransformCellVIew to magnify the data.
  • Jfer2u
    Yes that would be correct.  My company has a new logo for placement on chip.  I streame dthe gds file in but it is way to large for wher I would like to place it.  I have never converted anything to a pcell.  Where is this performed from the menu?  or do you execute from icfb?
    You can use dbCreateXformPCell() to create yourself a pcell which gives you a parameter to set the magnitude (and angle) of the shapes within the pcell. This is described in
    Essentially what you'd do is open the cellView you want to create a scaling pcell for in the layout editor, and then in the CIW type:
    dbCreateXformPCell(geGetEditCellView() "libNameYouWantThePCellIn")
    and it will create a cellView in that library with the same cellName as the original, but with a view "layout_xform".
    Note that you shouldn't use this with anything with a huge amount of contents, as it has to flatten the information within the cellView in order to do the scaling.
    Note that another alternative is to scale the layout - you can do that using the "XScale" UNIX command. Type it with no arguments and you'll get the help - so if you have the original layout and are OK to change it, then you can use XScale to do this.
    Neither of these are on menus.
  • Miguel V
    Miguel V over 10 years ago
    I am looking for the XScale command but whenever I type it in the CI box, all I get is
    *Error* toplevel: undefined variable - XScale
    I see that the tool is included in the documentation but we can't access it.  Any ideas?
    Miguel
    Miguel,
    As I mentioned earlier in the thread, this is a UNIX command, not a SKILL function to be executed in the CIW. You have to invoke it from a UNIX terminal.
  • Miguel V
    Yes I saw that after the fact and managed to find it with the other cadence tools.  I got it to work now.
    Miguel
