  3. switching regulator stability simulation (spectre/pss)
  • Views 1726
david0526
david0526 over 11 years ago
hello,
i'm trying to set up a simulation to check stability of a switching regulator (loop gain/phase of the control loop).  i found a previous post by Andrew referencing a paper he wrote for the UK National Microelectronics Institute specifically on this subject.
Andrew, if you can point me to the paper (i was not able to find it on the web) I'd greatly appreciate it.
thanks in advance,
david
    David, please send me a friend request on the forum, and then I can send you the paper.
  • david0526
    Andrew, done!
