  3. CDB 2 OA Error and warning
  • Views 15197
pejman saleh
pejman saleh over 11 years ago
i convert my cdb lib ( tsmc90rf) to oa with cadence ic 615
i have one error and 3 warnings
WARNING (CDBOA-512): OpenAccess does not support layer purpose specification in
standardViaDefs. All via layers are created and display
only on purpose drawing. Layer purpose PDKREC wellbody of
device DFM_M1_SUB/symbolic maps to PDKREC drawing in
standardViaDef PDKREC.
WARNING (CDBOA-513): OpenAccess does not recognize purpose wellbody used in
standardViaDef DFM_M1_SUB. No layer purpose PDKREC drawing
is defined. Creating layer purpose PDKREC drawing. Mapping
PDKREC wellbody to PDKREC drawing.
device M1_SUB/symbolic maps to PDKREC drawing in
standardViaDef M1_SUB. No layer purpose PDKREC drawing is
ERROR (CDBOA-126): cdb2oail error: "exec of
'/opt/Cadence/IC615/tools/dfII/bin/cdb2oail' failed with
signal 11."
Finished at: Jan 27 14:34:04 2015
364 cells and 2326 cellviews were translated from library 'tsmcN90rf' in 108.5s.
Message Summary:
ERROR (CDBOA126): cdb2oail error
Generated once. cdb2oa calls another executable cdb2oail
for supplementry uprev routines like technology, cmx and
cph. One or more uprevs have failed. This is an internal
program error. If you are unable to isolate the problem,
contact your Cadence Customer Support representative for
help.
only on purpose drawing. Layer purpose <layer> <purpose> of
device <cell>/<view> maps to <layer> drawing in
standardViaDef <via>.
Generated 2 times. OpenAccess does not support layer
purpose specification in standardViaDefs. All via layers
are created and display only on purpose drawing. The shapes
generated inside the via are on the drawing purpose.
WARNING (CDBOA-513): OpenAccess does not recognize purpose <purpose> used in
standardViaDef <via>. No layer purpose <layer> drawing is
defined. Creating layer purpose <layer> drawing. Mapping
<layer> <purpose> to <layer> drawing.
purpose specification in standardViaDefs. All layers are
can i ignore warning ?
how can i fix this error ? and warnings
merci
  • theopaone
    theopaone over 11 years ago
    The internal description of stdViaDefs does not support purposes other than drawing. I would add the LPP: PDKREC drawing to your techfile, modify your symbolic contacts or cdsVias to use this LPP. Re-translate and see if you get the error. Since the error message is not verbose, I would start with that.
    If you must have the LPP PDKREC, wellbody, you will have to create a customViaDef which can have the proper LPP.
    Ted
