  3. region and reversed in transient results
  • Views 23715
syafiq
syafiq over 11 years ago
I was looking at the transient results (using result browser), I saw two parameters which are region and reversed.
I belief region is referring to operating region of the MOS transistor as below. But I need a confirmation from you guys if this is correct?
region = 0 : cut off
region = 1 : linear
region = 2 : saturation
region = 3 : sub-threshold
region = 4 : breakdown
Another thing which I completely unsure is reversed. What does it mean actually by this parameter? It got number assigned into it.
example: reversed = 0. Could you help to explain what is 'reversed' and what the meaning of the number?
Syafiq Mispan
    Hi Syafiq,
    As far as I know, reversed is an indication that the transistor is connected the opposite way to the convention - in other words for an NMOS device, the source voltage is above the drain voltage. So in this netlist:
    // example showing two transistors, one "reversed"
    model nch bsim4 type=n
    M1 (d g 0 0) nch w=1u l=0.2u
    M2 (0 g d 0) nch w=1u l=0.2u
    Vd (d 0) vsource dc=2
    Vg (g 0) vsource dc=1
    dc dc
    dcOpPoint info what=oppoint where=screen
    M2 shows reversed=yes, and M1 shows reversed=no.
    The region information can be seen by doing "spectre -h bsim4" (or whichever device you are using). In the Operating Point Parameters section it has:
    1       region=triode     Estimated operating region. Spectre outputs the number (0-4) in a rawfile. Possible values are off, triode, sat, subth,
                              and breakdown.
    2       reversed          Reverse mode indicator. Possible values are no and yes.
    3       ids (A)           Resistive drain-to-source current.
    The numbers are in the order listed.
    For a "bjt" device, it shows:
    3       region=fwd        Estimated operating region. Spectre outputs number (0-4) in a rawfile. Possible values are off, fwd, rev, sat, and
                              breakdown.
    so the meaning is different dependent upon the device, as I stated above.
  • syafiq
    Hello Andrew,
    Thanks. Your explanation has clarified my concerns.
    Syafiq
  • syafiq
    Hello Andrew,
    I got one more concern. I ran dc simulation to know my circuits operating region. Basically you can load the raw file into result browser and go to dcOpInfo to check the region of transistor.  But I got quite a lot of transistor =256 transistors.  My I know how to extract the region for every single transistor?
    And another question what is the difference between Id and Ids? I thought both are the same which is referring to the drain current of the MOS transistor, but sometime it gave same value, sometime NOT.
    Syafiq
