  3. change default beep sound in cadence
  • Views 18780
Litstbl
Litstbl over 11 years ago
when I use virtuoso schematic and layout, there is a beep when I click save, or if there is an error, or when a simulation is finished. I think by default this beep comes from the BIOS. But I now have a computer that doesn't play that sound from the BISO. I wonder if there is a way to change that sound to a different one that can be played by the normal sound card, like other system notification.
Is this possible to do? Any one can help? Thanks a lot!
    Options->User Preferences in the CIW. There is "Beep Volume" there. This can also be controlled using:
    ui      beepVolume      int     0
    in the ~/.cdsenv file.
    There's also the UNIX command "xset -b" which may help.
    For me, I'm not getting beeps at all, but I can't remember what I've  configured in the past to address this.
  • Litstbl
    Thanks a lot Andrew. You are always here :)
    Actually I didn't make myself clear. My cadence has no problem, and it beeps through the BISO, so adjusting the volume doesn't solve my problem.
    The problem is with my computer, which doesn't make the beep (I guess there is some problem with the BISO), so I wonder if there is a way to change the beep to a different sound, to use the soundcard, instead of the BIOS beeping.
    When I use a different computer, I can hear the beep. It's just the new computer which can not make the sound through the motherboard.
    Actually I prefer to have the beep sound
    Hope I made myself clear this time.
    Thanks!
    I don't know the answer I'm afraid. Nowadays I'm running my Linux setup via a Virtual Machine so it's much harder for me to test direct issues with the BIOS interactions. I'd suggest going to customer support at http://support.cadence.com
