  3. How to retrieve an output from every Monte Carlo iterat...
  • Views 21557
How to retrieve an output from every Monte Carlo iteration
syafiq
syafiq over 11 years ago
I have the results from 100 iterations of Monte Carlo simulation. In each of the iteration, I need to find the value of voltage at a time using 'value' function.
However, to do it manually for 100 iterations, really tedious and wasting a lot of time. Imagine that I need to rerun my Monte Carlo simulation, and redo the extraction of voltage values manually?
I hope there is a better way to do this. But I couldn't find the right function to read the expression and give me the value of voltage for every iteration.
Hope somebody who has an experience, pls share.
Syafiq
    Are you running from ADE XL?
  • syafiq
    Hello Andrew
    Yes, I am running using ADE XL.
    Syafiq
    ShawnLogan over 11 years ago
    Dear Syafiq,
    If you are familiar with ocean, my recommendation would be to write a quick script to retrive the data by traversing the database hierarchy. I do this quite often after an ADEXL run of 100 to 200 corners.
    Shawn
    I wrote a lengthy answer to this earlier, but it seems to have vanished, so here goes again...
    Syafiq,
    This is something you can do using built-in facilities of the tool - no need to use as complex an approach as Shawn is suggesting. Certainly doesn't need any scripting to do this.
    In ADE XL you can set up an output expression for a test, such as value(VT("/out") 100n) and then that scalar calculation will be performed at each point in the monte carlo. Once that is done, you can then plot a histogram of the distribution, or you can switch to the Detail or Detail Transpose view of the results (rather than the default Yield view) and see the values for each iteration in the monte carlo. You can plot these scalar results, or you can export them to a CSV file, or using the little histogram icon you can print values per point and do many other operations.
    If you turn on saving of family data (use the little cog icon next to the run mode selector - so where you have "Monte Carlo Sampling" rather than "Single Run Sweeps and Corners"), you can also add new output expressions after the simulation has completed, and then use the Re-evaluate icon in the Results pane to calculate those per iteration too.
    It's pretty straightforward. You might also want to work your way through the ADE XL Rapid Adoption Kit. Go to
    and then at the top of the page, Resources->Rapid Adoption Kits. Then Custom IC and Signoff, and finally you'll find a workshop for ADE XL.
  • syafiq
    Thanks Shawn for your comment. It gave me another option. But I think at the moment, I'll go for Andrew's way to extract the voltage.
    Andrew, your method works finely. And now I was trying to use analog2digital function to convert the values that have been extracted to binary numbers.
    However, it does not seem to work correctly. If you look at the attached file, it only give me the binary values when there is a transition high/low or low/high.
    Resulted, not all voltages at specified time get its binary values.
    Anyway, I can copy the table in step 1 and use excel to convert to binary values. I just think it might be good if I can do post-processing in cadence environment.
    P/S: I was not able to upload the image.
    I agree, this should be possible (I think I understand what you mean).
    You should raise this with customer support
