  3. stb analysis phase plot starting from 0 degree
  • Views 22313
apple419
apple419 over 11 years ago
   I am doing a stb analysis on a opamp which is in unity-gain configuration.
   At some process corners, the phase plot actually stats from 0 degree and then goes up to 90 then falls back.
   I checked the transient simulations and it looks fine, without stability issues.
   So why phase starts from 0? does this mean at DC there is a positive feedback?
Thanks a lot!
  • Frank Wiedmann
    Frank Wiedmann over 11 years ago
    You can find an answer to your question at http://www.designers-guide.org/Forum/YaBB.pl?num=1294178255.
