  3. How to use constraints to create a symmetric layout (with...
  • Views 16341
How to use constraints to create a symmetric layout (with abutted MOS) using schematicXL and Layout XL (No modgens)
svats000
svats000 over 11 years ago
I am trying to layout a simple diff-pair and cascode cell (no tail and load devices, that is separate) using Virtuoso schematicXL and layoutXL.
I am trying to use constraints. I do not have license for LayoutGXL (so I cannot do Modgens). This is a 16nm process
Let the 2 cascode devices be A and B, and let the dummies be D.
I need something like this in the layout :  ( DDDDAAAAAAAADDDDDDDDBBBBBBBBDDDD)
How do I go about doing this without using modgens?
I have tried defining constraints (symmetry in placement and routing, and matched instance color), but I am unable to abut devices if I do that.
Another issue is: All the bold and underlined Ds above share the source with A or B, but have gates same as other Ds.
Hence, they need to be defined as separate devices in the schematic and appear as a separate single device when you generate layout from source. This means more maneuvering to place each of these single devices.
I am not getting any benefit so far from the many options in Layout XL. Are there any settings/controls that I can tweak to make better use of the tool?
Any help much appreciated. Regards,
    Please contact customer support - that would be the best way forward here.
