  3. Issue facing in executing the skill code..
  • Views 14860
varunkumar
varunkumar over 11 years ago
My purpose is to create a GUI form in which I can pass the points in the form itself..error getting in hiCreatePoitnList function.
m  variable is a points I want to pass  as a input...to create a blockage layer on the given points.
procedure(metal_entry()
let((l m layer_list)
layer_list=list("zero" "M1" "M2" "M3" "M4" "M5" "M6" "B1" "B2" "IA" "IB")
cv=geGetEditCellView()
tlist=list("C28")
?formTitle "CREATE BLOCK"
?callback `block
?unmapAfterCB t
status = hiDisplayForm( Via_form )
hiSetBindKey("Layout" "Shift<Key>V" "metal_entry()")
procedure(block(aform)
if(aform->techField->value=="C28" then
layer_list=list("M1" "M2" "M3" "M4" "M5" "IA" "IB")
foreach(lay layer_list
dbCreateLayerBlockage(cv "lay" "routing" m)
  • varunkumar
    error in pasting the code following code on which I am workingprocedure(metal_entry()
    tlist=list("C28")
    Techno=hiCreateCyclicField(
    ?name 'techField
    ?prompt "technology"
    ?value "C28"
    ?defValue "C28"
    ?choices tlist
    MetalLayerT=hiCreateCyclicField(
    ?name 'TOP_METAL
    ?prompt "top_layer"
    ?value "M1"
    ?defValue "M1"
    ?choices layer_list
    MetalLayerB=hiCreateCyclicField(
    ?name 'BOTTOM_METAL
    ?prompt "bottom_layer"
    ?value "M1"
    ?defValue "M1"
    ?choices layer_list
    ?name 'coordinate
    ?prompt "co-ordinate"
    ?value "M1"
    ?defValue "M1"
    ?choices layer_list
    point_list=
    hiCreatePointListField(
    ?name l
    ?value "m"
    hiCreateAppForm(
    ?name 'Via_form
    ?fields list(Techno MetalLayerT MetalLayerB)
    ?callback `block
    ?unmapAfterCB t
    The code was rather messy and hard to read - difficult to know your intentions. Maybe this is what you meant?
    procedure(metal_entry(m)
      let((layer_list tlist Techno MetalLayerT MetalLayerB point_list status cv)
        tlist=list("C28")
          ?name 'techField
          ?value "C28"
          ?defValue "C28"
          ?choices tlist
          ?name 'TOP_METAL
          ?prompt "top_layer"
          ?value "M1"
          ?defValue "M1"
          ?choices layer_list
          ?name 'BOTTOM_METAL
          ?value "M1"
          ?defValue "M1"
          ?choices layer_list
        point_list=hiCreatePointListField(
          ?name 'coordinate
          ?value m
        hiCreateAppForm(
          ?name 'Via_form
          ?fields list(Techno MetalLayerT MetalLayerB point_list)
          ?callback `block
          ?unmapAfterCB t
    hiSetBindKey("Layout" "Shift<Key>V" "metal_entry(list(0:0 1:0 1:1 0:1))")
