  3. parasitic resistance extract minimum value
  • Subscribers 133
  • Views 15002
archive over 18 years ago
Hi, I'm using Diva to extract RC parasitic.
I  saw in the DivaEXT.rul file that minimum mesured resistance value are 0.001 or 0.05 depending on the case. The problem is that it takes too much time to run.
there is a maximum (0.1 or 0.5 for instance...) value I can set to keep the reality of the simulation but using less running time
Thanks!!!!
Originally posted in cdnusers.org by isazul
    e
