  3. gpdk045
  • Views 19013
gpdk045
analogy
analogy over 11 years ago
Why do you have DRC errors (Nwell width) even when using pmos1v with default parameter values ?
    I think this is just a pragmatic decision. Given that you are fairly unlikely to have a single minimum width transistor on its own, most likely you will have other devices in the same well. By not drawing the well at minimum width, it gives you more freedom to stretch the well above or below the device. If it always drew the well at minimum width, and you were then placing the device in a wide-enough well (due to another wider transistor), it would limit where you could place the transistor alongside it.
    This is a wild guess though. Given that the process is a fictional process, it's all a bit arbitrary!
  • analogy
    Okay.And lastly what is integrated and detached body type ? Yes, it does increase implant area, but there is no mention of it in the documentation.Is it specific to gpdk045 ?
    Thanks.
    The two choices add a well or substrate contact (depending on the gender of the transistor). The integrated means it is directly abutting the source region, whereas the detached means it is separated from the source. This appears in various real PDKs too.
  • analogy
    Thanks.
