  3. How to remove the warning popup when traversing layout hierarchy...
  • Views 15322
How to remove the warning popup when traversing layout hierarchy?
herbl
herbl over 11 years ago
I have an issue where when I either Descend or Return in the layout hierarchy, a warning popup "Please Specify Diffusion Layer List"  would appear at each level, and having to repeatedly close the window is really annoying and time-consuming. Is there a way to remove this warning popup, or how to find out what's causing this?
    This message doesn't (as far as I know) come from Virtuoso itself, but from some customization. You might want to check:
    deGetAppInfo("maskLayout")->userAppTrigList
    deGetAppInfo("maskLayout")->userMenuTrigList
    deGetAppInfo("maskLayout")->userPostInstallTrigList
    to see if there are any user-defined triggers which might be doing this. Also try "virtuoso -nocdsinit" to see if it goes away if you do that.
