  3. gpdk 180 nm library error
  • Views 22127
eashwar g
eashwar g over 11 years ago
when a nmos and pmos from gpdk180 library is used .,i am getting few errors
Error found by spectre during circuit read-in.
    ERROR (SFE-396): "/cad/FOUNDRY/gpdk180/models/spectre/diode.scs" 11: Model `ndio' has already been defined.
    ERROR (SFE-396): "/cad/FOUNDRY/gpdk180/models/spectre/diode.scs" 17: Model `pdio' has already been defined.
Time for Elaboration: CPU = 26.996 ms, elapsed = 29.125 ms.
Time accumulated: CPU = 453.93 ms, elapsed = 531.76 ms.
Peak resident memory used = 31.2 Mbytes.
spectre terminated prematurely due to fatal error.
can anyone suggest the solution to this
  • theopaone
    theopaone over 11 years ago
    The GPDK is a Cadence product, you may want to direct your request to Cadence support.
    The most likely explanation is that you've accidentally included the model files twice. Look in Setup->Model Libraries (and Setup->Simulation Files) to see if that's the case if using ADE. In the spectre netlist, look for two include files.
  • eashwar g
    yes ... i figured it out ,i had put 45nm library file..thanks for the solution
