  3. Problem with MOS Bulk Routing Parasitic Resistance Extr...
  • Replies 11
  • Subscribers 133
  • Views 21517
Problem with MOS Bulk Routing Parasitic Resistance Extraction
Stepan
Stepan over 11 years ago
During the Spectre netlist generation process, I have found out that the Assura QRC extractor includes the parasitic resistances of the MOS transistor bulk routing in the extraction view:
rg58 (vdda \5\:vdda) resistor r=24.5376 c=0
But, it skips connecting this parasitic resistor to the bulk of the transistor:
M10 (\3\:vout \5\:nclk \2\:vin vdda) p_lv_18_mm w=1.92e-06 l=2.4e-07 ad=2.224e-13 as=2.224e-13 pd=2.0u ps=2.0u m=(1)*(1)
From the line above, you can see that it circumvents the parasitic resistor and connects the bulk directly to the polarization net vdda (NOT \5\:vdda)
As a result, the simulation netlist generated from this extracted view is also incorrect.
I have tried two different technologies with two different design kits and both have the same issue. Two kits are:
1. Virtuoso Design Environment version IC6.1.3.500.13 with Cadence Extraction QRC - Parasitic Extractor - Version 8.1.4-p002.
2. Virtuoso Design Environment version IC6.1.5-64b.500.132 with Cadence Extraction QRC - Parasitic Extractor - Version 11.1.2-p106.
Is there any way to fix this problem? Can it be done by modifying the configuration script or updating the kit?
Stepan.
  • RobinCommander
    RobinCommander over 9 years ago
    This has now been logged with customer support. Case 46109305
    In our case we are extracting diodes where one of the terminal is Nwell or psub. We create local areas of Nwell or psub where diode marker is present.
    Robin
