  3. ICS1526
  • Subscribers 133
  • Views 14379
ICS1526
archive over 18 years ago
ICS1526 General Description The ICS1526 is a low-cost, high-performance frequency generator. It is suited to general purpose phase controlled clock synthesis as well as line-locked and genlocked high-resolution video applications. Using ICS’s advanced low-voltage CMOS mixed-mode technology, the ICS1526 is an effective clock synthesizer that supports video projectors and displays at resolutions from VGA to beyond XGA. The ICS1526 offers single-ended clock outputs to 200 MHz. The HSYNC_out, and VSYNC_out pins provide the regenerated versions of the HSYNC and VSYNC inputs synchronous to the CLK output. The advanced PLL uses its internal programmable feedback divider. The device is programmed by a standard I2C-busTm serial interface and is available in a TSSOP16 package. Features • Lead-free packaging (Pb-free) • Low jitter (typical 27 ps short term jitter) • Wide input frequency range • 8 kHz to 100 MHz • LVCMOS single-ended clock outputs • Up to 200 MHz • Uses 3.3 V power supply • 5 Volt tolerant Inputs (HSYNC, VSYNC) • Coast (ignore HSYNC) capability via VSYNC pin • Industry standard I2C-bus programming interface • PLL Lock detection via I2C or LOCK output pin • 16-pin TSSOP package Applications • Frequency synthesis • LCD monitors, video projectors and plasma displays • Genlocking multiple video subsystems ICS1526 Functional Diagram Pin Configuration (16-pin TSSOP) More about ICS1526: www.chinaicmart.com/.../ICS1526.html
Originally posted in cdnusers.org by zxy888
