  3. ERROR (VACOMP-1008): Cannot compile ahdlcmi module libr...
  • Subscribers 133
  • Views 2919
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library
FormerMember
FormerMember over 11 years ago
Hello~
I got this error while doing some simulation on our server.
I attached a ahdlcmi.out and the result of the command
$: specter -W
sub-version 13.1.087.isr1
$: uname -a
Linux <servername> 2.6.18-371.1.2.e15 #1 SMP Tue Oct 22 12:51:53 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
$:  cat /etc/redhat-release
CentOS release 5.10 (Final)
  • FormerMember
    Sorry, the ahdlcmi.out has been renamed as ahdlcmi.txt and attached to this post.
    Fullscreen ahdlcmi.txt Download
    ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB//2605_Spectre_models__._dgmvcap.va.dgmosvarcap.ahdlcmi/Linux-64/ for Linux-64 with optimize using gcc on Thu Feb 12 14:47:55 PST 2015 [5.0]
    ahdlcmicompile: Generating makefile
    PATH:  /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.1-x86_64/install/bin:/cad/MMSIM131/bin:/cad/MMSIM131/tools/bin/64bit:/cad/MMSIM131/tools/bin:/cad/IC615/bin:/cad/IC615/tools/bin:/cad/IC615/tools.lnx86/bin/64bit:/cad/IC615/tools.lnx86/bin:/cad/IC615/share/oa/bin:/cad/IC615/tools/bin/64bit:/cad/Calibre/ixl_cal_2013.3_39.24/bin:/cad/IC615/tools/dfII/bin:/cad/IUS8.2/tools/bin:/cad/MMSIM131/tools/dfII/bin:/cad/IC615/tools/dfII/bin:.:/cad/IC615/tools/dfII/bin:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin
    LD_LIBRARY_PATH:  /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.1-x86_64/install/lib:/cad/MMSIM131/tools/giganta/lib/64bit:/cad/MMSIM131/tools/mdl/lib/64bit:/cad/MMSIM131/tools/mmsim/lib/64bit:/cad/MMSIM131/tools/inca/lib/64bit:/cad/MMSIM131/tools/spectre/lib/64bit:/cad/MMSIM131/tools/dfII/lib/64bit:/cad/MMSIM131/tools/lib/64bit:/cad/MMSIM131/tools/lib:/cad/IC615/tools/lib:/cad/IC615/share/oa/lib/linux_rhel40_gcc44x_64/opt:/cad/IC615/tools.lnx86/Qt/64bit/lib:/cad/IC615/tools.lnx86/dfII/lib/64bit:/cad/IC615/tools.lnx86/sev/lib/64bit:/cad/IC615/tools.lnx86/lib/64bit:/cad/IC615/tools.lnx86/lib:/cad/IUS8.2/tools.lnx86/lib/64bit:/cad/IC615/tools/Qt/64bit/lib:/cad/IC615/tools/dfII/lib/64bit:/cad/IC615/tools/sev/lib/64bit:/cad/IC615/tools/lib/64bit
    Can't exec "mpstat": No such file or directory at /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/getCPUnum.pl line 41.
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j2 -f GNUmakefile
    Cleaning ./obj/optimize/5.0
    rm -f -rf ./obj/optimize/5.0
    Compiling C file dgmosvarcap_func.c (optimize) with -O0
    Compiling C file dgmosvarcap_DcFuncDerLoad.c (optimize)
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include -c dgmosvarcap_func.c -o obj/optimize/5.0/dgmosvarcap_func.o || rm -f -f obj/optimize/5.0/dgmosvarcap_func.o
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include -c dgmosvarcap_DcFuncDerLoad.c -o obj/optimize/5.0/dgmosvarcap_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/dgmosvarcap_DcFuncDerLoad.o
    <stdin>: In function 'dgmosvarcap_DcFuncDerLoad':
    <stdin>:1035: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1518: note: expected 'void *' but argument is of type 'long int'
    <stdin>:1036: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1037: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1038: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1039: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1040: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1041: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1042: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1045: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1046: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1047: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1048: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    rm -f -rf dgmosvarcap_func.c
    Compiling C file dgmosvarcap_DcFuncLoad.c (optimize)
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include -c dgmosvarcap_DcFuncLoad.c -o obj/optimize/5.0/dgmosvarcap_DcFuncLoad.o || rm -f -f obj/optimize/5.0/dgmosvarcap_DcFuncLoad.o
    rm -f -rf dgmosvarcap_DcFuncDerLoad.c
    Compiling C file dgmosvarcap_TranFuncDerLoad.c (optimize)
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include -c dgmosvarcap_TranFuncDerLoad.c -o obj/optimize/5.0/dgmosvarcap_TranFuncDerLoad.o || rm -f -f obj/optimize/5.0/dgmosvarcap_TranFuncDerLoad.o
    <stdin>: In function 'dgmosvarcap_TranFuncDerLoad':
    <stdin>:1051: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1052: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1053: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1054: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1055: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1056: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1057: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1058: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1061: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1062: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1063: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    <stdin>:1064: warning: passing argument 1 of 'aslDevInterAddStaticElement' makes pointer from integer without a cast
    rm -f -rf dgmosvarcap_DcFuncLoad.c
    Compiling C file dgmosvarcap_TranFuncLoad.c (optimize)
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include -c dgmosvarcap_TranFuncLoad.c -o obj/optimize/5.0/dgmosvarcap_TranFuncLoad.o || rm -f -f obj/optimize/5.0/dgmosvarcap_TranFuncLoad.o
    rm -f -rf dgmosvarcap_TranFuncDerLoad.c
    Compiling C file dgmosvarcap_OpPointCalc.c (optimize)
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include -c dgmosvarcap_OpPointCalc.c -o obj/optimize/5.0/dgmosvarcap_OpPointCalc.o || rm -f -f obj/optimize/5.0/dgmosvarcap_OpPointCalc.o
    rm -f -rf dgmosvarcap_TranFuncLoad.c
    Compiling C file dgmosvarcap_cmi_c.c (optimize) with -O0
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/bin/64bit/ahdlcc 0 /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc  -march=k8 -ffast-math -O0 -m64 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include -I/cad/MMSIM131/tools.lnx86/cmi/include -c dgmosvarcap_cmi_c.c -o obj/optimize/5.0/dgmosvarcap_cmi_c.o || rm -f -f obj/optimize/5.0/dgmosvarcap_cmi_c.o
    <stdin>: In function 'dgmosvarcap_pDC_Load':
    <stdin>:2292: warning: passing argument 1 of 'aslDevFillZeorDiagonalElemet' makes pointer from integer without a cast
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1947: note: expected 'void *' but argument is of type 'long int'
    <stdin>: In function 'dgmosvarcap_pGetMatrixPointers':
    <stdin>:2333: warning: assignment makes integer from pointer without a cast
    <stdin>: In function 'dgmosvarcap_pAnalTranLoad':
    <stdin>:2366: warning: passing argument 1 of 'aslDevFillZeorDiagonalElemet' makes pointer from integer without a cast
    <stdin>: In function 'dgmosvarcap_pSaveRestart':
    <stdin>:2392: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type
    /cad/MMSIM131/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:1164: note: expected 'struct ahdlAnalogVar *' but argument is of type 'char *'
    <stdin>: In function 'dgmosvarcap_pSaveRestartInst':
    <stdin>:2395: warning: passing argument 2 of 'aslDevAvarSR' from incompatible pointer type
    rm -f -rf dgmosvarcap_OpPointCalc.c
    rm -f -rf dgmosvarcap_cmi_c.c
    /cad/MMSIM131/tools.lnx86/cdsgcc/gcc/4.4/bin/gcc -shared -O0 -m64 -fPIC -o obj/optimize/5.0/dgmosvarcap_libahdlcmi.so ./obj/optimize/5.0/dgmosvarcap_func.o ./obj/optimize/5.0/dgmosvarcap_DcFuncDerLoad.o ./obj/optimize/5.0/dgmosvarcap_DcFuncLoad.o ./obj/optimize/5.0/dgmosvarcap_TranFuncDerLoad.o ./obj/optimize/5.0/dgmosvarcap_TranFuncLoad.o ./obj/optimize/5.0/dgmosvarcap_OpPointCalc.o ./obj/optimize/5.0/dgmosvarcap_cmi_c.o  -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
    ld: cannot find -lc
    collect2: ld returned 1 exit status
    gnumake: *** [obj/optimize/5.0/dgmosvarcap_libahdlcmi.so] Error 1
    ld: cannot find -lc
    The failure appears to be about it not being able to find libc (which should be at /usr/lib64/libc.so since it is compiling in 64-bit mode by the looks of things).
    On a RHEL5.8 machine I have to hand, this is:
    UNIX> rpm -q -f /usr/lib64/libc.so
    glibc-devel-2.5-81.x86_64
    So you should check if you have the 64-bit glibc-devel rpm installed.
