  3. How to include parameter weight in ocean function ocnxlPutMaxSpec...
  • Views 15837
How to include parameter weight in ocean function ocnxlPutMaxSpec?
fanshujiao
fanshujiao over 11 years ago
I am running ADE GXL optimization by ocean script. When I run optimization in Cadence GUI, there is option which I can specify weights for performance specifications. Whereas in ocean function
ocnxlPutMaxSpec(t_testName t_resultName t_maxValue)
There is no parameter option for weight. How do I include weight in ocean script? Is the option provided by other functions?
Thank you very much.
Fanshu
    I filed a CCR for the documentation, because it talks about specifying the weight as a positional argument, but in fact it is a keyword argument (as can be seen by adding the weight in the ADE XL UI, and then using File->Save Script). The CCR number is 1375817.
    So for example, you'd do:
    ocnxlPutMaxSpec( "TRAN" "SettlingTime" "10n" ?weight "2")
  • fanshujiao
    Thank you very much for your reply. I tried what you suggested, but it doesn't work. The error is
    *Error* ocnxlPutMinSpec: too many arguments (3 expected, 5 given) - ("macroModel:4_1:1" "rmsNoise" "130.2u" ?weight "0.001")
    ocnxlPutMinSpec is defined as:
    ocnxlPutMinSpec(t_testName t_resultName t_minValue)
    I guess ocnxlPutMinSpec is not allowed to include weight parameter. It must be some other ways, but I don't know how.
    You must be using an ancient version -  this is exactly why the Forum Guidelines ask you to specify the version you are using.
    The IC612 version of virtuoso supports this ?weight argument with ocnxlPutMinSpec, whereas the IC611 (and presumably IC610 - I don't have that around anywhere) do not.  That's true of all the Spec functions, I think, not just the MinSpec version. IC612 was released in October 2007, so I'm not sure why you'd be running a 7.5 year old version (it's not like there is a big migration path like there is from IC5141 to IC61X), assuming that's your problem.
    Typing:
    getVersion(t)
    will tell you the subversion you are using.
