  3. seeing all warnings
  • Subscribers 133
  • Views 17895
seeing all warnings
freitas
freitas over 11 years ago
I'm getting the following message in my irun.log:
WARNING (SPECTRE-8529): Dangling instance.
hvbms_tb.dut.siliconrevision.R21.rrm3 is removed.
Further occurrences of this warning will be suppressed.
How to I get the full list of warnings?
    In general you can control this with the Simulation->Options->Analog (Spectre) form, and then go to the Annotation tab, and in the maxwarnstologfile enter a big number (the default in the simulator is 5). However, there are some parser warnings that come before this option is read, in which case you might need to use Simulation->Options->AMS Simulator, and then on the Main tab, in Additional Arguments enter:
    -spectre_args "-maxwarnstolog 500"
    or some other suitably large number.
    If running irun from the command line, you'd do this with:
    irun ... -spectre_args "-maxwarnstolog 500"
    If using the first approach, you'd add:
    myOpts options maxwarnstologfile=500
    to the analog control file (the .scs file you pass to irun with the options and analysis statements).
