  3. Plotting two signals vs. each other
  • Views 19479
itos
itos over 11 years ago
I have two signals from "pss_td" which I would plot vs. each other. Of course, it's the prominent gain plot vs. output, i.e.:
plot(dB20(mag(v("/RFout" ?result "pss_fd"))), dB20(mag(v("/RFout" ?result "pss_fd"))/mag(v("/RFin" ?result "pss_fd"))));
I use the "Results Browser" from ADE L, i.e. "Virtuoso Visualization and Analysis, Waveform Graph XL, version IC6.1.6-64b.500.8".
I was pretty sure I used that already (at least when I did sweeps using the Parametric Analysis) but I cannot find it anywhere.
Clicking on the axis for example only shows "Axis properties" where I can set the format but no signal source.
Thanks!
itos
  • Frank Wiedmann
    Frank Wiedmann over 11 years ago +1
    When you right-click on the x axis, there should be an item "Y vs Y...". There you can select the trace that should be used as the new x axis.
  • Frank Wiedmann
  • itos
    Aaah, now I know what I did wrong:
    I need to have plotted both signals on the same plot, then I can select one of them to be the x-axis ....
