  3. ACPD
  • Views 15191
ACPD
ACPD
ACPD over 11 years ago
Could you please suggest me a flow  How to use  Auto rout in IC 6.1.5 For custom floor-plan?
    Did you consider reading the manual or looking at the Rapid Adoption Kits (Resources->Rapid Adoption Kits) on http://support.cadence.com ? Your question is rather non-specific and open ended (not sure what ACPD is either).
  • ColinSutlieff
    ColinSutlieff over 11 years ago
    the question is very general.
    But, as a starting point, you should  launch LayoutXL or LayoutGXL
    Then run the router using the "route" menu.
    Prerequisite is to have a layout, or floorplan containing connectivity, so a schematic should normally be available
    Colin
  • ACPD
    Thank you Andrew . Yes I am started reading manual..ACPD(Automated Custom Physical Design) .
  • ACPD
    Thank you Colin. I have Schematic & Floorplan done by manually . I am using XL but Devices in floorplan did not contain connectivity . Is there any method to create connectivity according to schematic other than (Gen from schematic).
