  3. warnings
  • Views 15276
warnings
Sali
Sali over 11 years ago
Dear all,
I'm receiving bunch of warnings but the circuit works may be not in an optimal mode ,can someone help me.
*WARNING* (TECH-230035): User-defined rule "minOverlapDistance" in constraint
                         group "default" of techDB "cmrf8sf" conflicts with
                         a built-in constraint with the same name.
                         You may write out "constraintGroups" section to an
                         ASCII file, reopen the technology database in "a"
                         mode, and reload the file to update the database.
                         Another option is to rename this rule.
Problem while loading expression: E0 already exists.
Problem while loading expression: E1 already exists.
*WARNING* (icLic-3) Could not get license Analog_Design_Environment_L
*WARNING* (icLic-21) License Analog_Design_Environment_L ("95200") is not available to run ADE-L.
Trying to check out the license Analog_Design_Environment_XL ("95210") instead.
*INFO* (icLic-25) License Analog_Design_Environment_XL ("95210") was used to run ADE L.
Delete psf data in /home/salibensuleiman/simulation/CNNrPLATrainingSimulation/spectre/schematic/psf.
generate netlist...
*WARNING* Pattern "warning" not found.
WARNING (OSSHNL-145): Incremental netlisting is not possible since the netlist in this run directory
Warning from spectre at time = 1 ms during transient analysis `tran'.
    WARNING (SPECTRE-16266): Error requirements were not satisfied because of convergence difficulties.
    Random unrelated warnings from different tools at different points in the flow with little context as to what you were doing... not so easy to deal with (which probably explains why it has been ignored for 3 weeks).
    You appear to have (from a bit of a guess) warnings from the technology setup, loading the calculator in ViVA, licensing, incremental netlisting (where you're only showing part of the warning) and the simulation itself.
    The licensing issue can be controlled by Options->Licensing, and then the Order tab.
    Can't comment much on the others, since there's no context.
