  3. ocnxlOutputSummary on a calculated variable
  • Views 15537
Fabb
Fabb over 11 years ago
Instead plotting a calculated variable (var1 in the example below), I would like to save it. To do So I use ocnxlOutputSummary, but I have this error
*Error* eval: undefined function - _ocniGetXLProjDir
Can you help me.
Fabrice
paramRun()
selectResult( 'tran )
var1= (cross(VT("/state") 0.5 1 "either" nil nil) - 1e-09)
plot( TauSwitch ?expr '( "var1" ) )
ocnxlOutputSummary(?exprSummary t ?specSummary t ?detailed t ?wave t ?fileName "myOutPutfile")
    It looks as if you are mixing OCEAN and OCEAN XL functions. paramRun() is not used in an OCEAN XL script, and ocnxlOutputSummary is not used in an OCEAN script. I've found some reports of this in the past (using old versions) but didn't think it happened nowadays - I got a clear error when I tried something similar.
    Probably you want to use ocnPrint(var1) or similar? Or even an fprintf()?
  • Fabb
    Thanks Andrew for your answer.
    Indeed I was not aware about the impossibility to mix ocn and acnXL script.So I chose ocnprint() function like this:
    paramRun()
    ocnPrint( ?output "./myOutputFile" getData("var1")
    it run pretty well but i can't find ./myOutputFile.
    Something I miss ?
    regards,
    Fabrice
    Fabrice,
    This should go in your working directory. However, I do notice that you are missing a close parenthesis on the ocnPrint - not sure if that's the error?
