  3. how to add a spice netlist component and how to simulate...
  • Replies 7
  • Views 26616
how to add a spice netlist component and how to simulate it
eashwar g
eashwar g over 11 years ago
i tried adding the following spice code using this link
simulator lang=spice
.SUBCKT memristor Pside Nside PARAMS:
+ Ron=1K Roff=100K Rinit=80K D=10N uv=10F p=1
* DIFFERENTIAL EQUATION MODELING *
Gx 0 x value={ I(Emem)*uv*Ron/D^2*f(V(x),p)}
Cx x 0 1 IC={(Roff-Rinit)/(Roff-Ron)}
Raux x 0 1T
* RESISTIVE PORT OF THE MEMRISTOR *
Emem plus aux value={-I(Emem)*V(x)*(Roff-Ron)}
Roff aux minus {Roff}
*Flux computation*
Eflux flux 0 value={SDT(V(plus,minus))}
*Charge computation*
Echarge charge 0 value={SDT(I(Emem))}
* WINDOW FUNCTIONS
* FOR NONLINEAR DRIFT MODELING *
*window function, according to Joglekar
.func f(x,p)={1-(2*x-1)^(2*p)}
*proposed window function
;.func f(x,i,p)={1-(x-stp(-i))^(2*p)}
.ENDS memristor
i get these errors
Error found by spectre in `memristor', during circuit read-in.
    ERROR (SFE-1024): "/home/eashwar/Desktop/model" 23: Instance `Cx': Unexpected value `/' - positional parameters are not allowed after explicitly named parameters.
    ERROR (SFE-1024): "/home/eashwar/Desktop/model" 23: Instance `Cx': Unexpected value `Roff-Ron' - positional parameters are not allowed after explicitly named parameters.
Warning from spectre in `memristor', during circuit read-in.
    WARNING (SFE-1805): "/home/eashwar/Desktop/model" 43: .func is not recognised as a valid SPICE control card.
how to use this code to create a component ,..,so that we can use this model for further simulations
please suggest steps
    This can be solved by:
    1. Removing the simulator lang= line from the model file
    2. Use the pspice_include statement to include it rather than include. This was introduced in MMSIM13.1, and is also available in ADE in IC616 (under Setup->Simulation Files)
    3. Finally spectre seems to interpret the "^" operator in the model file as a bitwise XOR operator, whereas looking at the context of the model, ^ appears to be an exponent. I checked the PSPICE (Allegro AMS Simulator to give its real name) documentation, and ^ is indeed an XOR operator. If this is meant to be an exponent, change the occurrences of ^ to **. Other than this, the model looks pretty PSPICE-like though...
    Doing all this, the model can be parsed and simulated. I have not checked whether it functions correctly though.
  • eashwar g
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 11.1.0.523.isr15 32bit -- 6 Sep 2012
    can't i use pspice code ?
    how to check mmsim version,
    is that version relevant?
    That's MMSIM11.1 (the clue is in the version 11.1.XXX - the spectre version number corresponds to the MMSIM stream version number). As I mentioned, PSPICE support is not available until MMSIM13.1, so you are using too old a version.
  • eashwar g
    so cant i use this code in mmsim11.1
    there is no solution for this ??
    Yes, the solution is to move to MMSIM13.1 or MMSIM14.1! Not sure why that would be an issue? A customer under a maintenance contract (or a University) has access to these. The alternative would be to rewrite everything into native spectre approaches, which is not an entirely trivial task... and when there is a simpler solution of using a release from the last 2 years rather than a 3-4 year old release, it seems a no-brainer to me...
  • eashwar g
    is this a big procedure to move..
    if it can be upgraded using existing license
    can u provide the steps to do so
    First of all, there is no tax on characters in this forum. The forum guidelines ask you not to use "instant messaging shorthand" - using words such as "u" tends to disincline me from answering...
    I don't know which license version you have - you might have a license installed for the latest version - in which case installing a later version of MMSIM is straightforward. If  you are a customer with maintenance, you can go to support.cadence.com and use the Software->Software Updates menu to order a new license file.
