  3. Setting option duplicatemodel=ignore in spectre does not...
  • Replies 7
  • Views 7598
Setting option duplicatemodel=ignore in spectre does not work
Frode Telsto
Frode Telsto over 11 years ago
I run ADEXL (IC6.1.6) and want to redefine a model, and have tried to add duplicatemodel=ignore in my spectre simulations. I have tried to add:
myOpt options duplicatemodel=ignore
in my modelfile that is included in the simulations.
I have also tried to add duplicatemodel=ignore in Options->Analog->Miscellaneous->OTHER OPTIONS->Additional Arguments.
But I still get an error when I run my simulation: ERROR: .... Model `nch' has already been defined.
    Hi Frode,
    A couple of things. Are you using a recent enough MMSIM version (this was introduced during the life of MMSIM11.1, I believe) - I expect so?
    The other thing is that if the model is a subckt model, this won't help - you'd have to use duplicate_subckt instead (or as well).
  • Frode Telsto
    I am using mmsim13.10.186_isr5.
    I am trying to map the TSMC nch model over to nch_mac model by typing:
    model nch nch_mac
    in my model include file. This works if I comment out the mos section in the TSMC model file, but if I would like to  avoid modifying the TSMC file.
    The nch_mac is an inline subckt.
    I tried to add:
    myOpt options duplicate_subckt=ignore
    before the model mapping line in my model include file, but get the same error.
    Hi Frode,
    I'll try with an older version later - I only have the latest hotfix of MMSIM13.1 with me right now.
    This example works fine for me - maybe you can check running spectre on this netlist:
    model nch bsim4 type=n
    inline subckt nch_mac (d g s b)
        parameters w=1u l=1u
        nch_mac (d g s b) nch_mac w=w l=l
        model nch_mac bsim4 type=n
    ends nch_mac
    myOpts options duplicatemodel=ignore
    // new definition to map it...
    model nch nch_mac
    M0 (D G 0 0) nch w=2u l=0.2u
    VD (D 0) vsource dc=1.2
    VG (G 0) vsource dc=0.8
    dc dc
    Hi Frode,
    I tried the above example in the same subversion as you, and it worked OK.
    Maybe contacting customer support so that we can take a look together would be a good idea? You can always mention that we've discussed it on the forums and that I'd be happy to look at it with you.
  • Frode Telsto
    Thanks for your input. It helped me finding that the problem is binning. Your example works for me too, but when I add binning to the model it fails. See my modified example below.
    Frode
    model nch bsim4 {
    1:type=n
    2:type=n
    model nch_mac bsim4 {
    1:type=n
    2:type=n
    ends nch_mac
    model nch nch_mac
    dc dc
    Hi Frode,
    I see the problem. The good news is that in more recent subversions, the problem has been fixed. I can see the problem in versions up to 13.1.1.292.isr12, but not in 13.1.1.420.isr14 (I don't have ISR13 handy) - it works there. Similarly it works in 14.1.0.255.isr2 (not in the base version of MMSIM14.1, and I don't have ISR1 handy either). I did a very quick search and couldn't see precisely what triggered this to get fixed, but my experimentation shows it working nowadays at least.
    So please try with a later (or the latest) hotfix of either MMSIM13.1 or MMSIM14.1.
    Kind Regards,
  • Frode Telsto
    Thanks Andrew,
    I tried version 14.1.0.400.isr4 and then it works.
    Unfortunately I have to stick to the workaround where I modify the TSMC model file as I'm working on a company wide setup, and it may take a while till all projects have changed to the latest version of mmsim.
    Frode
