  3. schematic transfer between different versions
  • Views 17657
Faizan UL HAQ
Faizan UL HAQ over 11 years ago
I found somewhere that dbWriteSkill command can be used to generate .il extension file for a schematic. This .il extension file can be loaded back to other versions of virtuoso to get the schematics back in other versions.
I ran the following commands in CIW to generate .il extension file for my schematic
cvId = dbOpenCellViewByType("myLib" "myPcell" "schematic")
dbWriteSkill(cvId "/tmp/dumpFile.il" "w" "6.1")
However, i don't know how to load back this dumpFile.il back in virtuoso as schematic. guidance required.
    This is NOT a good idea. There is really no support for using dbWriteSkill in this way - there's no guarantee that this will work reliably between versions. To answer the specific question, you'd use load("/tmp/dumpFile.il") but you shouldn't do this in my opinion.
    Which versions are you trying to translate between?
  • Faizan UL HAQ
    Actually i have to copy design files from one CMOS process design kit to another CMOS process design kit.  My original intention was to create a skillcode of all schematic design files using dbWriteSkill() command in one design kit  and then try to edit the code in such a way, that i replace the transistor models with second design kit models. Later on i import the edited code back to cadence.  In this way, i was thinking that i will not have to change manually the transistor models (which can take long time). However, as you suggested this is probably not the right way.
    A more time consuming way to do this design transfer from one CMOS process design kit to another CMOS process design kit will be to copy the design library and then change all the transistor models in each schematic manually. Is there is any way, i can change all transistor models with just one command in skill language.
    I answered this via your other recent post on the same topic (essentially)
