  3. CMOS Inverter Switching Threshold
  • Views 16534
mkza1002
mkza1002 over 11 years ago
I kindly request you to guide me to get a plot of switching threshold of a CMOS Inverter against the ratio of Wp/Wn along the x-axis, where Wp is the variable width of PMOS and Wn is the variable width of NMOS.
Thank you.
Mohammad Kashif.
  • analogy
    analogy over 11 years ago
    You cannot have two varying parameters. When you say Wp/Wn, you change Wp with respect to fixed Wn.
  • analogy
    Instead plot Wp on X-axis and parameterize Wn.Sweeping Wp and Wn with same ranges and taking their ratio would result in constant x-axis value.
